查看: 6405|回复: 0
这个vhdl程序运行不出来结果是怎么回事
    2020-6-29 12:52
    发表于 2020-6-29 13:16:27 | 显示全部楼层 |阅读模式
    我查了说是时钟对那个逻辑不起作用,但是怎么改啊
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_unsigned.all;
    entity lk_lc is
    port(CLK,LP,LR,cnt_1,cnt_2,cnt_3:in std_logic;
          LEDLut std_logic_vector(2 downto 0));
    end;
    architecture behave of lk_lc is
    signal cnt:std_logic_vector(24 downto 0);
    signal cnt_1 : std_logic;
    signal cnt_2 : std_logic;
    signal cnt_set : std_logic;
    begin
    process(CLK,LP,LR)
    variable count : integer range 0 to 2 := 0;
    begin
    if LP = '0' then
    LEDL<= (others=>'0');
    count := 0;
       elsif CLK'event and CLK='1' then
        if cnt_set = '1' then
      case count is
          when 0 =>     LEDL <= "001";
        when 1 =>     LEDL <= "010";
        when 2 =>      LEDL <= "100";
        when others=>     null;
      end case;
      if count = 2 then
              count := 0;
        else    count := count + 1;
         end if;
       end if;
    end if;
    end process;
    process(LP,clk)
    begin
    if LP = '0' then
      cnt <= (others=>'0');
      cnt_1 <= '0';  cnt_2 <= '0';  cnt_set <= '0';
      elsif clk'event and clk = '1' then
         if cnt_2 = '0' and cnt_1 = '1' and cnt(23)='1' then
          cnt_set <= '1';
       else   cnt_set <= '0';
       end if;
       cnt <= cnt + 1;  cnt_2 <= cnt_1;  cnt_1 <= cnt(23);
    end if;
    end process;
    end behave;
    GMT+8, 2026-11-4 00:03 , Processed in 0.050088 second(s), 34 queries .
