TA的每日心情 | 难过 2018-8-25 09:43 |
- 积分
- 199
在DAC实验里
modelsim仿真波形正常
但实际电压表测试电压均为0V
期间怀疑过DAC芯片 但出产固件测试DB引脚 电压正常增长
故可以排除DAC芯片问题 应该是驱动当中出了什么问题
ISSP设置如下
实在找不出来问题出在哪里
后附上各文件代码
DAC_top
- module DAC_top(
- clk,
- rst_n,
- key,
- DIN,
- CS_N,
- SCLK
- input clk,rst_n;
- input key;
- output wire DIN;
- output wire CS_N;
- output wire SCLK;
- wire [15:0] DAC_DATA;
- wire DAC_STATE;
- reg START;
- DAC_driver DAC_driver(
- .clk (clk),
- .rst_n (rst_n),
- .START (START),
- .DAC_DATA (DAC_DATA),
- .CS_N (CS_N),
- .SCLK (SCLK),
- .DIN (DIN),
- .DAC_STATE (DAC_STATE)
- DAC DAC_test (
- .probe (DAC_DATA[11:0]), // probes.probe
- .source (DAC_DATA) // sources.source
- reg [15:0] DAC_DATA_r;
- always@ (posedge clk or negedge rst_n)
- if(!rst_n)
- DAC_DATA_r <= 16'd0;
- else if (DAC_STATE)
- DAC_DATA_r <= DAC_DATA;
- else
- DAC_DATA_r <= DAC_DATA_r;
- if(!rst_n)
- START <= 1'b0;
- else if (DAC_DATA_r != DAC_DATA)
- START <= 1'b1;
- else
- START <= 1'b0;
- endmodule
DAC_driver
- `define DIV_PARAM 2
- module DAC_driver(
- clk,
- rst_n,
- START,
- DAC_DATA,
- CS_N,
- SCLK,
- DIN,
- DAC_STATE
- input clk,rst_n;
- input START;
- input [15:0] DAC_DATA;
- output reg CS_N;
- output reg SCLK;
- output reg DIN;
- output DAC_STATE;
- /* 处理 START 信号 */
- /* 当出现 START 信号时,work = 1 表示正在工作不接受触发
- 当出现 conv_finish 信号时,work = 0 表示不在工作可以被触发 */
- reg work;
- reg conv_finish;
- always@ (posedge clk or negedge rst_n) begin
- if(!rst_n)
- work <= 1'b0;
- else if ( conv_finish )
- work <= 1'b0;
- else if (START)
- work <= 1'b1;
- else
- work <= work;
- end
- /* SCLK2X 时钟产生 */
- /* 数据手册显示 TLV5618 最大时钟频率20MHz
- 所以取SCLK2X 频率为25MHz 即进行2分频
- 如此 SCLK 即为 12.5 MHz 符合器件要求 */
- reg [7:0] cnt_SCLK2X;
- if(!rst_n)
- cnt_SCLK2X <= 8'd0;
- else if (work) begin
- if (cnt_SCLK2X == ( (`DIV_PARAM) - 1'b1 ) )
- else
- cnt_SCLK2X <= cnt_SCLK2X + 1'b1;
- end
- else
- end
- reg SCLK2X;
- if(!rst_n)
- SCLK2X <= 1'b0;
- else if ( work && ( cnt_SCLK2X == ( (`DIV_PARAM) - 1'b1 ) ) )
- SCLK2X <= 1'b1;
- else
- SCLK2X <= 1'b0;
- end
- /* 线性序列计数器 */
- reg [5:0]cnt_LSM;
- if(!rst_n)
- cnt_LSM <= 6'd0;
- else if ( work && SCLK2X ) begin
- if ( cnt_LSM == 6'd33 )
- cnt_LSM <= 6'd0;
- else if (SCLK2X)
- cnt_LSM <= cnt_LSM + 1'b1;
- end
- else
- cnt_LSM <= cnt_LSM ;
- end
- /* 线性序列机 */
- if(!rst_n)
- else if (work)
- else
- end
- if(!rst_n) begin
- CS_N <= 1'b1;
- DIN <= 1'b1;
- SCLK <= 1'b1;
- end
- if (SCLK2X) begin
- case (cnt_LSM)
- 0: begin SCLK <= 1'b0; CS_N <= 1'b0; end
- 1: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[15]; end
- 3: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[14]; end
- 5: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[13]; end
- 7: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[12]; end
- 9: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[11]; end
- 11: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[10]; end
- 13: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 9]; end
- 15: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 8]; end
- 17: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 7]; end
- 19: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 6]; end
- 21: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 5]; end
- 23: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 4]; end
- 25: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 3]; end
- 27: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 2]; end
- 29: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 1]; end
- 31: begin SCLK <= 1'b1; DIN <= DAC_DATA_r[ 0]; end
- 2,4,6,8,10,12,14,16,18,20,22,24,26,28,30:
- begin SCLK <= 1'b0; end
- 32: begin SCLK <= 1'b1; end
- 33: begin CS_N <= 1'b1; end
- default : begin CS_N <= 1'b1; DIN <= 1'b1; SCLK <= 1'b1; end
- endcase
- end
- else ;
- end
- else CS_N <= 1'b1;
- end
- /* 当数据转换完成时候输出一个 conv_finish 信号脉冲 */
- if(!rst_n)
- conv_finish <= 1'b0;
- else if ( work && SCLK2X && (cnt_LSM == 6'd33) )
- conv_finish <= 1'd1;
- else
- end
- assign DAC_STATE = work;
- endmodule
DAC_tb
- `timescale 1ns/1ns
- `define timeperiod 20
- module DAC_tb();
- reg clk,rst_n;
- reg START;
- reg [15:0] DAC_DATA;
- wire CS_N;
- wire SCLK;
- wire DIN;
- wire DAC_STATE;
- .clk (clk),
- .rst_n (rst_n),
- .START (START),
- .CS_N (CS_N),
- .SCLK (SCLK),
- .DIN (DIN),
- initial clk = 1'b0;
- always #(`timeperiod / 2) clk = ~clk;
- initial begin
- rst_n = 1'b0;
- #(`timeperiod * 10);
- rst_n = 1'b1;
- #(`timeperiod * 20);
- DAC_DATA = 16'hC_AAA;
- START = 1;
- #20;
- START = 0;
- #200;
- wait(!DAC_STATE);
- #2000;
- DAC_DATA = 16'h4_555;
- START = 1;
- #20;
- START = 0;
- #200;
- wait(!DAC_STATE);
- #2000;
- #2000;
- $stop;
- end
- endmodule
DAC_TLV5618.zip
(3.98 KB, 下载次数: 2412)
