查看: 14141|回复: 1
仿真报错:near text "if"; expecting operand
    2019-8-5 22:11
    发表于 2019-8-5 22:15:44 | 显示全部楼层 |阅读模式
    module test(clk,rst_n,dv,data,num);
      input clk;
      input rst_n;
      input dv;
      input [7:0]data;
      output [3:0]num;
      reg [3:0]cnt;//寄存器类型变量
      reg [2:0]state;//寄存器类型变量
      always@(posedge clk or negedge rst_n)
        if(!rst_n)begin
          state<=3'd0;
                    cnt<=4'd0;
        else begin
                    case(state)
            if(data=="w")
                        state<=3'd1;
              state<=3'd0;
                    if(data=="e")
                      state<=3'd2;
                    else if (data=="w")
            state<=3'd1;
                      state<=3'd0;
                    if(data=="l")
                      state<=3'd3;
                    else if (data=="w")
            state<=3'd1;
                      state<=3'd0;
                    if(data=="c")
                      state<=3'd4;
                    else if (data=="w")
            state<=3'd1;
                      state<=3'd0;
                    if(data=="o")
                      state<=3'd5;
                    else if (data=="w")
            state<=3'd1;
                      state<=3'd0;
                    if(data=="m")
                      state<=3'd0;
                      cnt<=cnt+1'd1;
                    else if (data=="w")
            state<=3'd1;
                      state<=3'd0;
                    default:state<=3'd0;
             endcase
    仿真报错:Error (10170): Verilog HDL syntax error at test.v(21) near text "if";  expecting an operand
    请问是哪里出问题了呢?
    发表于 2019-8-8 20:58:38 | 显示全部楼层
    case格式错了吧,case不是这么用的呀,if前面缺少了他们各自所在的状态。
    GMT+8, 2026-11-1 01:00 , Processed in 0.052438 second(s), 36 queries .
