查看: 8163|回复: 1
【求助】有限状态机的condition不完整
    郁闷
    2019-12-26 16:14
    发表于 2019-12-26 16:07:11 | 显示全部楼层 |阅读模式
    一个101的序列检测器,源代码如下
    1. module block1(
    2.         din,
    3.         clk,
    4.         rst_n,
    5.         Qout
    6. );
    7.         input din,clk,rst_n;
    8.         output reg Qout;
    9.         parameter S0 = 2'b00;
    10.         parameter S1 = 2'b01;
    11.         parameter S2 = 2'b11;
    12.
    13.         reg [1:0]current_state;
    14.         reg [1:0]next_state;
    15.
    16.         always@(posedge clk or negedge rst_n)
    17.         begin
    18.                 if(!rst_n)
    19.                 begin
    20.                         current_state <= S0;
    21.                 end
    22.                 else
    23.                 begin
    24.                         current_state <= next_state;
    25.                 end
    26.         end
    27.
    28.         always@(current_state or din)
    29.         begin
    30.                 case(current_state)
    31.                 S0:
    32.                 begin
    33.                         if(din == 1)
    34.                         begin
    35.                                 next_state = S1;
    36.                                 Qout = 1'b0;
    37.                         end
    38.                         else
    39.                         begin
    40.                                 next_state = S0;
    41.                                 Qout = 1'b0;
    42.                         end
    43.                 end
    44.                 S1:
    45.                 begin
    46.                         if(din == 1)
    47.                         begin
    48.                                 next_state = S1;
    49.                                 Qout = 1'b0;
    50.                         end
    51.                         else
    52.                         begin
    53.                                 next_state = S2;
    54.                                 Qout = 1'b0;
    55.                         end
    56.                 end
    57.                 S2:
    58.                 begin
    59.                         if(din == 0)
    60.                         begin
    61.                                 next_state = S1;
    62.                                 Qout = 1'b1;
    63.                         end
    64.                         else
    65.                         begin
    66.                                 next_state = S0;
    67.                                 Qout = 1'b0;
    68.                         end
    69.                 end
    70.                 default:
    71.                 begin
    72.                         next_state = S0;
    73.                         Qout = 1'b0;
    74.                 end
    75.                 endcase
    76.         end
    77. endmodule
    此时的状态机为图一
    把S2的if改成if(din==1)之后,状态机为图二,其condition少了一半,是什么原因,怎么调整?
    图一
    图一
    图二
    图二
    擦汗
    2020-2-13 22:59
  • 2
    发表于 2019-12-28 22:56:11 | 显示全部楼层
    把S2的if改成if(din==1)之前
    系统的输出逻辑还是对的
    状态机内的部分可能出现BUG了。。。
    GMT+8, 2026-9-17 02:56 , Processed in 0.055481 second(s), 39 queries .
