查看: 7521|回复: 0
麻烦大家帮我看看这个ADC模块为什么不能在issp中看结果,仿...
    萌哒
    2020-7-2 11:17
    发表于 2020-6-23 20:31:55 | 显示全部楼层 |阅读模式
    //顶层模块,ADC模块在后面
    module    top_adc1208(
        input    wire            clk,
        input    wire            rst_n,
        input    wire            ADC_DOUT,
        output    wire        ADC_CLK,
        output    wire        ADC_CS_n,
        output    wire        ADC_DIN,
        output    reg    [3:0]    led
    wire    [2:0]    channel;
    wire    [11:0]    data;
    wire            ADC_Ding;
    adc128s022 adc128s022_inst(
        .clk        (clk),
        .rst_n        (rst_n),
        .channel    (channel),//ADC通道选择
        .En_Conv    (ADC_Ding),//单周期使能信号
        .ADC_DOUT    (ADC_DOUT),//ADC转换结果输出给FPGA
        .ADC_CLK    (ADC_CLK),//ADC时钟信号,由FPGA给ADC
        .ADC_DIN    (ADC_DIN),//ADC通道选择,由FPGA给ADC
        .ADC_CS_n    (ADC_CS_n),//ADC使能信号
        .data        (data),//FPGA将接受的ADC转换数据输出
        .ADC_Ding    (ADC_Ding)//转换完成信号
    //ISSP IP核
    ts    ts_inst (
        .probe ( {data,channel} ),
        .source ( channel )
    //ADC模块
    module    adc128s022(
        input        wire            clk,
        input        wire            rst_n,
        input        wire    [2:0]    channel,//ADC通道选择,外部给与,再由FPGA给ADC
        input        wire            En_Conv,//单周期使能信号
        input        wire            ADC_DOUT,//ADC转换结果输出给FPGA
        output    reg            ADC_CLK,//ADC时钟信号,由FPGA给ADC
        output    reg            ADC_DIN,//ADC通道选择,由FPGA给ADC
        output    reg            ADC_CS_n,//ADC使能信号
        output    reg    [11:0]    data,//FPGA将接受的ADC转换数据并行输出
        output    reg                ADC_Ding//转换完成信号(数据已经并行输出)
    parameter        DIV_MAX = 4'd12;//分频计数器最大值(fclk/DIV_MAX*2)
    reg    [2:0]    r_channel;//通道选择寄存
    reg    [11:0]    r_data;//寄存转换结果
    reg            en;//使能信号
    reg    [3:0]    div_cnt;//分频计数器
    reg            flag;//计数标志
    reg    [5:0]    cnt;//序列计数器
    //在每个使能转换的时候,寄存Channel的值,防止在转换过程中该值发生变化
    always@(posedge clk or negedge rst_n)
    begin
        if(!rst_n)
            r_channel <= 3'd0;
        else if(En_Conv)
            r_channel <= channel;
            r_channel <= r_channel;
    //单脉冲使能信号
    always @ (posedge clk or negedge rst_n)
    begin
        if(!rst_n)
            en <= 1'b0;
        else if(En_Conv)
            en <= 1'b1;
        else if(ADC_Ding)
            en <= 1'b0;
            en <= en;
    //分频计数器
    begin
        if(!rst_n)
            div_cnt <= 4'd0;
        else if(en)begin
                if(div_cnt == DIV_MAX)
                    div_cnt <= 4'd0;
                    div_cnt <= div_cnt + 1'b1;
            div_cnt <= 4'd0;
    //计数标志
    begin
        if(!rst_n)
            flag <= 1'b0;
        else if(en && (div_cnt == DIV_MAX))
            flag <= 1'b1;
            flag <= 1'b0;
    //序列计数器
    begin
        if(!rst_n)
            cnt <= 6'd0;
        else if(en && flag)begin
                if(cnt == 6'd33)
                    cnt <= 6'd0;
                    cnt <= cnt + 1'b1;
            cnt <= cnt;
    begin
        if(!rst_n)begin
            ADC_CLK <= 1'b1;
            ADC_DIN <= 1'b1;
            ADC_CS_n <= 1'b1;
            r_data <= 12'd0;
        else if(en)begin
                if(flag)begin
                    case(cnt)
                        6'd0    :    ADC_CS_n <= 1'b0;
                        6'd1    :    begin ADC_CLK <= 1'b0; ADC_DIN <= 1'b0;end
                        6'd2    :    ADC_CLK <= 1'b1;
                        6'd3    :    ADC_CLK <= 1'b0;
                        6'd4    :    ADC_CLK <= 1'b1;
                        6'd5    :    begin ADC_CLK <= 1'b0; ADC_DIN <= r_channel[2];end
                        6'd6    :    ADC_CLK <= 1'b1;
                        6'd7    :    begin ADC_CLK <= 1'b0; ADC_DIN <= r_channel[1];end
                        6'd8    :    ADC_CLK <= 1'b1;
                        6'd9    :    begin ADC_CLK <= 1'b0; ADC_DIN <= r_channel[0];end
                        //每个上升沿,寄存ADC串行数据输出线上的转换结果
                        6'd10,6'd12,6'd14,6'd16,6'd18,6'd20,6'd22,6'd24,6'd26,6'd28,6'd30,6'd32:
                        begin ADC_CLK <= 1'b1; r_data <= {r_data[10:0], ADC_DOUT}; end    //循环移位寄存DOUT上的12个数据
                        6'd11,6'd13,6'd15,6'd17,6'd19,6'd21,6'd23,6'd25,6'd27,6'd29,6'd31:
                        begin ADC_CLK <= 1'b0; end
                        default        :    ;
                    endcase
                else    ;
            ADC_CS_n <= 1'b1;
    begin
        if(!rst_n)begin
            data <= 12'd0;
            ADC_Ding <= 1'b0;
        else if(en && flag && (cnt == 6'd33))begin
            data <= r_data;
            ADC_Ding <= 1'b1;
        else begin
            data <= data;
            ADC_Ding <= 1'b0;
    GMT+8, 2026-10-31 22:48 , Processed in 0.052582 second(s), 34 queries .
