查看: 8996|回复: 0
运行警告如何修改
发表于 2021-6-6 21:18:59 | 显示全部楼层 |阅读模式
请前辈指导如下警告,并如何修改多谢:
Warning (332009): The launch and latch times for the relationship between source clock: PLL|altpll_component|auto_generated|pll1|clk[3] and destination clock: PLL|altpll_component|auto_generated|pll1|clk[0] are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0.
Warning (13024): Output pins are stuck at VCC or GND
        Warning (13410): Pin "Sd_CS_N" is stuck at GND
        Warning (13410): Pin "Sd_Dqm[0]" is stuck at GND
        Warning (13410): Pin "Sd_Dqm[1]" is stuck at GND
http://file:///C:\\Users\\fyu\\AppData\\Roaming\\Tencent\\Users\\2075574720\\TIM\\WinTemp\\RichOle\\5NFVF_EGSD08RXMBK}WBHIW.png
GMT+8, 2026-9-17 02:56 , Processed in 0.052030 second(s), 34 queries .
