查看: 10878|回复: 0
Error (10149):identifier "cnt3" is already declared in the present
    发表于 2021-8-13 16:49:10 | 显示全部楼层 |阅读模式
    Error (10149): Verilog HDL Declaration error at counter3.v(27): identifier "cnt3" is already declared in the present scope
    报错内容如上所述,原因在于某个信号在多个位置定义,如下面的代码,第10行定义了cnt3,在17行又定义了一次,就会出现这种报错。排查这种报错的方法很简单,找到其中一个位置,双击使其高亮,然后再在上下文中找其他地方定义的位置。
    1. module counter3(
    2.         Clk50M,
    3.         Rst_n,
    4.         led
    5. );
    6.         input Clk50M;        //系统时钟,50M
    7.         input Rst_n;        //全局复位,低电平复位
    8.         output reg led;
    9.         wire [24:0]cnt3;
    10.
    11.         counter2 counter2(
    12.                 .Clk50M(Clk50M),
    13.                 .Rst_n(Rst_n),
    14.                 .cnt2(cnt3)
    15.         );
    16.         wire [24:0]cnt3;
    17.     //led输出控制进程
    18.         always@(posedge Clk50M or negedge Rst_n)
    19.         if(Rst_n == 1'b0)
    20.                 led <= 1'b1;
    21.         else if(cnt3 == 25'd24_999)  //仅为测试
    22.                 led <= ~led;
    23.         else
    24.                 led <= led;
    25. endmodule
    GMT+8, 2026-10-13 16:56 , Processed in 0.053451 second(s), 35 queries .
