查看: 913|回复: 0
按键消抖改变LED灯状态板级验证无法通过
    2026-8-20 10:54
    发表于 2026-8-11 08:48:33 | 显示全部楼层 |阅读模式
    用的是ACX720开发板,在尝试按键消抖后控制LED灯改变状态,时钟频率是50Mhz,仿真波形符合预期,硬件上没有检测出问题。但是烧入比特流文件后,LED灯始终无法点亮。
    Verilog代码如下:
    module light
        parameter cnt=20'd999999
        input clk,
        input arst,
        input rkey,
        output reg light
        reg rkey_1;
        reg rkey_2;
        reg arst_1;
        reg arst_2;
        reg key;
        reg [19:0] counter;
    //先处理一下异步输入
        always @(posedge clk or posedge arst) begin
            if(arst) begin
                counter<=0;
                key<=0;
                rkey_1<=0;
                rkey_2<=0;
                arst_1<=1;
                arst_2<=1;
                light<=0;
            else begin
                    rkey_1<=rkey;
                    rkey_2<=rkey_1;
                    arst_1<=arst;
                    arst_2<=arst_1;
    //接着来处理按键消抖,按键本身摁下为低电平,但是处理后的按键信号key用高电平来表示摁下
        always @(posedge clk) begin
            if(!arst_2)begin
                if(rkey_2==0&&counter<cnt) begin
                    counter<=counter+1;
                else begin
                    if(rkey_2==1)
                    counter<=0;
            if(counter==cnt-1) key<=1;
            else key<=0;
    //最后处理LED灯的变化
            if(!arst_2)begin
                if(key==1) light<=~light;
    引脚绑定情况为异步复位接拨码开口,其它端口与名称对应
    set_property DRIVE 12 [get_ports light]
    set_property IOSTANDARD LVCMOS33 [get_ports arst]
    set_property IOSTANDARD LVCMOS33 [get_ports clk]
    set_property IOSTANDARD LVCMOS33 [get_ports light]
    set_property IOSTANDARD LVCMOS33 [get_ports rkey]
    set_property PACKAGE_PIN G22 [get_ports arst]
    set_property PACKAGE_PIN M22 [get_ports light]
    set_property PACKAGE_PIN B21 [get_ports rkey]
    set_property PACKAGE_PIN Y18 [get_ports clk]
    GMT+8, 2026-10-12 09:53 , Processed in 0.052860 second(s), 34 queries .
