查看: 10421|回复: 1
在Soc_EDS软件中不能启动DS-5,提示:$ bash: eclipse: 未找到命令
    发表于 2020-4-7 16:42:27 | 显示全部楼层 |阅读模式
    在设计时不能从在Soc_EDS的命令窗口中启动DS-5软件。窗口显示如下:
    即使已经进入到当前的eclipse目录下也是显示同样的信息。
    求各位有遇到过这问题的给个解答。
    现在我启动DS-5只能在Windows“开始”菜单里找到这个链接启动。我想可能是这样启动很多环境变量都没有自动加入,会造成之后的软件调试出现问题。
    我收集了以下的本机启动DS-5的信息。
    现有的启动文件Embedded_Command_Shell.bat如下:
    @ REM ###################################################
    @ REM #                                                 #
    @ REM # Intel FPGA SoC Embedded Command Shell           #
    @ REM #                                                 #
    @ REM # Execute this script to setup an environment for #
    @ REM # using the Intel FPGA Embedded Command Shell     #
    @ REM #                                                 #
    @ REM #                                                 #
    @ REM # Copyright (c) 2017 Intel Corporation            #
    @ REM # All Rights Reserved.                            #
    @ REM #                                                 #
    @ REM # Ensure extensions are enabled
    @ setlocal enableextensions
    @ REM # Discover the root embedded directory
    @ set _SOCEDS_ROOT=%~dp0
    @ set _SOCEDS_ROOT=%_SOCEDS_ROOT:\=/%
    @ REM # Variable to ignore <CR> in DOS
    @ REM # line endings
    @ set SHELLOPTS=igncr
    @ REM # Variable to ignore mixed paths
    @ REM # i.e. G:/$SOPC_KIT_NIOS2/bin
    @ set CYGWIN=nodosfilewarning
    @ REM # Allow user to override HOME,
    @ REM # otherwise provide sensible default
    @ if not defined HOME if defined USERPROFILE set HOME=%USERPROFILE%
    @ REM # Launch cygwin soceds command shell
    :run_soceds_command_shell
    @ "%_SOCEDS_ROOT%host_tools/cygwin/bin/bash.exe" --login -c '"%_SOCEDS_ROOT%embedded_command_shell.sh" %*'
    另外 相应的Embedded_Command_Shell.sh文件如下:
    #!/bin/bash
    # Get the Root SOCEDS directory
    if [ -n "${COMSPEC}" ]; then
        _IS_WINDOWS=1
        if [ "${SOCEDS_DESTROY_PATH}" == "1" ]; then
            export ORIGINAL_PATH="${PATH}"
            PATH="/bin:/usr/bin"
        fi
    fi
    if [ "${_IS_WINDOWS}" = "1" ] && [ -n "$(which cygpath 2>/dev/null)" ]; then
        _IS_CYGWIN=1
    fi
    _SOCEDS_ROOT=$(cd "$(dirname "${0}")" && echo "$(pwd 2>/dev/null)")
    if [ ! -d "${_SOCEDS_ROOT}" ]; then
        echo "${_SOCEDS_ROOT} not found. Invalid or corrupt SOCEDS Install" 1>&2
        exit 1
    fi
    export SOCEDS_DEST_ROOT="${_SOCEDS_ROOT}"
    if [ "${_IS_CYGWIN}" == "1" ]; then
        SOCEDS_DEST_ROOT="$(cygpath -m "${SOCEDS_DEST_ROOT}" 2>/dev/null)"
    fi
    source "${_SOCEDS_ROOT}/env.sh"
    unset _SOCEDS_ROOT
    unset _IS_WINDOWS
    unset _IS_CYGWIN
    if [ -n "$*" ]; then
        exec "$@"
        echo "------------------------------------------------"
        echo "Intel FPGA Embedded Command Shell"
        echo
        echo "Version 17.1 [Build 590]"
        # Use bash --norc to get a clean shell
        # Use bash --rcfile <bashrc> to for a user rcfile
        # Default to using ~/.bashrc
        exec bash
    fi
     楼主| 发表于 2020-4-8 09:16:15 | 显示全部楼层
    昨天自己将DS-5软件重新修复安装了一下。惊喜的是这个问题居然消失了。现在可以在这个命令行窗口下启动DS-5软件。
    GMT+8, 2026-11-26 20:39 , Processed in 0.052054 second(s), 35 queries .
