查看: 8237|回复: 0
使用power shell搜索文件内容
    发表于 2023-4-20 11:47:06 | 显示全部楼层 |阅读模式
    1. $path = 'G:\Dev_Temp\FPGA\AC590\AC590_SoC_GHRD\software\spl_bsp'
    2. $searchword = 'CONFIG_EMAC0_BASE'
    3. $Filename = '*.h'
    4. $filesWithKeyword = Get-ChildItem $path -Include "$Filename" -Recurse |Where-Object { $_ |Select-String -Pattern $searchword -SimpleMatch |Select-Object -First 1 }
    5. Write-Host "Contents of ArrayPath:"
    6. $filesWithKeyword.FullName
    GMT+8, 2026-11-26 20:37 , Processed in 0.052811 second(s), 35 queries .
