查看: 1435|回复: 0
在nios command shell中下载指定sof和elf文件并打开jtag uart串口的脚本
    发表于 2026-8-1 12:48:29 | 显示全部楼层 |阅读模式
    1. #!/bin/bash
    2. SOF_FILE='E:/FPGA_DEV/AC597/ddr3_nios/output_files/ddr3_nios.sof'
    3. ELF_FILE='E:/FPGA_DEV/AC597/ddr3_nios/software/ddr3_nios/ddr3_nios.elf'
    4. echo "============================================================"
    5. echo " AC597 DDR3 Nios II download script"
    6. echo "============================================================"
    7. echo
    8. echo "[1/4] Checking JTAG connection..."
    9. jtagconfig
    10. if [ $? -ne 0 ]; then
    11.     echo
    12.     echo "ERROR: JTAG connection check failed."
    13.     exit 1
    14. fi
    15. echo
    16. echo "[2/4] Programming FPGA with SOF..."
    17. quartus_pgm -m jtag -o "p;${SOF_FILE}"
    18. if [ $? -ne 0 ]; then
    19.     echo
    20.     echo "ERROR: SOF programming failed."
    21.     exit 1
    22. fi
    23. # Wait briefly for the newly configured Nios II/JTAG Debug Module
    24. # to become visible on the JTAG chain.
    25. sleep 1
    26. echo
    27. echo "[3/4] Downloading and starting ELF..."
    28. nios2-download -g "${ELF_FILE}"
    29. if [ $? -ne 0 ]; then
    30.     echo
    31.     echo "ERROR: ELF download failed."
    32.     exit 1
    33. fi
    34. echo
    35. echo "[4/4] Opening JTAG UART terminal..."
    36. echo "Press Ctrl+C to close the terminal."
    37. echo
    38. nios2-terminal
    GMT+8, 2026-11-26 19:47 , Processed in 0.058412 second(s), 35 queries .
