本代码用来测量CMOS 摄像头的帧率和PCLK频率。
将camera_param_get例化在工程顶层,连接复位、已知频率的一个时钟信号给Clk,并通过名为FCLK的parameter参数来告知该时钟的具体频率。把摄像头的PCLK、VSYNC信号连接到本模块。摄像头工作时就能读到Fps以及Fpclk的值了,Fps是帧率,Fpclk是PCLK频率。
Fps和Fpclk的值,可以使用ISSP、VIO等JTAG工具在电脑端软件实时查看,也可以通过串口发送给电脑,也可以连接数码管显示驱动显示在数码管上。
[C#] 纯文本查看 复制代码
module camera_param_get(
Clk,
Rst_n,
Pclk,
VSync,
Fps,
Fpclk
input Clk;
input Rst_n;
input Pclk;
input VSync;
output reg [7:0] Fps;
output reg[31:0]Fpclk;
parameter FCLK = 50_000_000;
reg [3:0] r_VSync;
always@(posedge Clk)
r_VSync <= {r_VSync[2:0],VSync};
reg [31:0]sec_cnt;
//计时1秒
always@(posedge Clk or negedge Rst_n)
if(!Rst_n)
sec_cnt <= 0;
else if(sec_cnt >= FCLK - 1)
sec_cnt <= 0;
sec_cnt <= sec_cnt + 1'd1;
//计数帧
reg [7:0] Fps_cnt;
if(!Rst_n)
Fps_cnt <= 0;
else if(sec_cnt == FCLK - 1)
Fps_cnt <= 0;
else if(r_VSync[3:2] == 2'b01)
Fps_cnt <= Fps_cnt + 1'd1;
Fps_cnt <= Fps_cnt;
//输出帧统计结果
Fps <= Fps_cnt ;
Fps <= Fps;
//考虑到PCLK有可能高于FCLK,所以先预分频
reg[7:0]pre_div_cnt;
always@(posedge Pclk or negedge Rst_n)
if(!Rst_n)
pre_div_cnt <= 0;
pre_div_cnt <= pre_div_cnt + 1'd1;
reg[3:0]r_pre256_pclk;
r_pre256_pclk <= {r_pre256_pclk[2:0],pre_div_cnt[7]};
reg [23:0]pre_pclk_cnt;
if(!Rst_n)
pre_pclk_cnt <= 0;
pre_pclk_cnt <= 0;
else if(r_pre256_pclk[3:2] == 2'b01)
pre_pclk_cnt <= pre_pclk_cnt + 1'd1;
pre_pclk_cnt <= pre_pclk_cnt;
if(!Rst_n)
Fpclk <= 0;
Fpclk <= {pre_pclk_cnt,8'd0};
Fpclk <= Fpclk;
testbench
[C#] 纯文本查看 复制代码
`timescale 1ns/1ns
module camera_param_get_tb;
reg Clk;
reg Rst_n;
reg Pclk;
reg Vsync;
reg Href;
reg [7:0]Data;
wire [7:0] Fps;
wire [31:0]Fpclk;
camera_param_get camera_param_get(
Clk,
Rst_n,
Pclk,
Vsync,
Fps,
Fpclk
initial Clk = 1;
always#100 Clk = ~Clk;
initial Pclk = 1;
always#4 Pclk = ~Pclk;
/*定义时序生成器输出图像的宽和高*/
parameter WIDTH = 1200;
parameter HIGHT = 720;
integer i,j;
initial begin
Rst_n = 0;
Vsync = 0;
Href = 0;
Data = 0;
#805;
Rst_n = 1;
#400;
repeat(15)begin
Vsync = 1;
#320;
Vsync = 0;
#800;
for(i=0;i<HIGHT;i=i+1)begin
for(j=0;j<WIDTH*2;j=j+1)begin
Href = 1;
Data = Data + 1;
#80;
Href = 0;
#800;
$stop;
camera_param_get.v
(2.36 KB, 下载次数: 2585)
camera_param_get_tb.v
(1.08 KB, 下载次数: 2548)
另外实测,大家使用我们给大家提供的初始化表,帧率设置30帧时候,PCLK为84M,15帧为42M,7.5帧为21M
